Results 1 to 5 of 5
  1. Collapse Details
    Question about quartz-based products
    #1
    Junior Member Detail Paradise Member aetb's Avatar
    Join Date
    Jun 2017
    Location
    Victoria
    Posts
    10
    Hi everyone, I'm new here so please be gentle
    I've been trying to find the answer to this question for a while now but can't really find a satisfactory answer:
    Why do most quartz-based products(Gyeon for example) recommend using a high-pressure water flow to 'activate' the product? What is the actual mechanism that is set in motion by the pressurised water, that doesn't work(well) any other way?
    Any insight would be A+ awesome
  2. Collapse Details
    #2
    Senior Member Detail Paradise Addict BlackButters's Avatar
    Join Date
    Oct 2013
    Location
    Perth
    Posts
    298
    No need for concern. People on this forum are very friendly.
    I've not heard of that, though I've only used cquartz and ism (great)
    Would be interested in knowing more about this..
  3. Collapse Details
    #3
    Join Date
    Feb 2017
    Posts
    21
    I'd say that it's to avoid getting runs or drying too thickly, hence the wet application and power rinse
  4. Collapse Details
    #4
    Senior Member Detail Paradise Addict KNGPN's Avatar
    Join Date
    Jan 2013
    Location
    Melbourne
    Posts
    2,323
    You need to specific about what you're talking about.
    My assumption is a product like Hydr02. This is part of their description
    Our "Hydroelectric bonding" function means HydrO2 reacts chemically with water contact! This means the coating transforms from Hydrophilic to Hydrophobic. The pressure from spraying with water accelerates the bonding of HydrO2 to the surface creating a Hydrophobic layer.
    I can't think of a coating that suggests using high pressure...most suggest not getting it wet for a period of time after application.
    Por que no los dos
    Quote Originally Posted by SMOKEY View Post
    Cheers Dan - but I think you're half the problem - why can't my paint look like yours after I've finished it!?! Unobtainable perfection! Haha
  5. Collapse Details
    #5
    Join Date
    Jun 2017
    Location
    Victoria
    Posts
    10
    Quote Originally Posted by KNGPN View Post
    Yep you're right, I should've been more specific I was meaning things like Gyeon Wetcoat which wants high pressure water used after setting-up for 10s or so, and wants to be applied only on a clean and wet surface.
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
